New Crank Or Old - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-27-2006, 06:21 PM
AMERICAN MUSCLE!!!!!!!!!
New Crank Or Old
Hello, Dont Have Alot Of $$$ To Spend On My 327 Sbc. Should I Buy A New Or Slightly Used Crank Or Have It Turned. Would I Loose A Hp. I Know I Would Have To Buy Diff. Bearings. Thanks
Old 01-27-2006, 06:27 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Have it checked it may just need polishing. But if it needs turning then have it turned. No you will not lose any power. After you have it turned get the proper size main bearings and rod bearings.
Old 01-27-2006, 09:46 PM
It has rust all over it
Old 01-27-2006, 11:15 PM
ASE Master but no genius
The rust will disappear during the turning process.
Old 01-28-2006, 01:17 AM
Barry.M's Avatar
Old Phart
Last wiki edit: How to identify a Ford V8
Last journal entry: 27 T Roadster project: Underway cont.
Wiki Edits: 3
Mic. it up.........measure it with a micrometer, not a vernier. If it's got some life left in it i.e. measures .030" thou. or less undersize, get it checked for straightness and cracks first. If its a small journal it'll be steel, if it's a large journal it could be cast or steel.
If it all ckecks out OK as above and it's a small journal, have it ground (turned), then polish it up.
If it's a Large Journal you've got more options. If it's a steel crank , go ahead as above. If it's cast crank you can go buy a steel crank or buy a 350 crank and turn it into a 350. Or you can replace your old "stuffed" crank with a budget 307 large journal cast crank which is the same stroke as your 327.
Hope that helps you out with some options.
Old 01-28-2006, 01:45 AM
If you have to turn it more than20/20 ,buy a new crank fom Ohio Crankshaft .. I am very Impressed with them .. The have a good Rep. and put out a excellent product .. For example a good friend of mine has a 650+ hp 454 with AFR (KILLER HEADS and on pump gas) with OHIO rod's and crank. Be extremley careful if its a small journal motor with stock parts if you are hammering it hard.. I am not saying they are garbage ,but I have wasted a few of them.. Also they can be a complete ANIMAL!! Been there also !!! Small journal motors majorly rev.Due to the light reciprocating assembly.Which is a known +. Take care and have fun,Because that's what it is all about..
Can't figure out what crank I have Mad Maggot Engine 3 11-06-2005 09:20 PM
Serious problems removing harmonic balancer! spyderdude Engine 55 06-09-2005 10:01 AM
Rebuilt engine won't crank. lt1bbody Engine 10 04-22-2005 12:44 PM
Scat 9000 crank VS stock 400 crank? MOORESPEED Engine 5 03-03-2005 10:54 AM
crank / block combo's toddtheodd Engine 5 03-17-2004 10:38 PM
