New Crank won't spin - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 04-24-2008, 07:11 PM
Piston are a Sealed Power 423NP. I would take them back and have them install right but I am in a small town and it 40 miles to the shop and geting someone to take me there is a pain plus I need this motor to be done. The motor is a 92 4.3 V6 piston are new.
  #17 (permalink)
Old 04-24-2008, 07:37 PM
King of my Man-cave.
The pistons will be clearly marked front with a notch on the top and and F near the end of the wrist pin bore. You need for 3 to be oriented with the notch to the front and the bearing tangs to the passenger side and 3 with the notch to the front and the bearing tangs to the driver side.
I'm still wondering about the bearing clearance. According to your numbers, you have .021" clearance.
tom
  #18 (permalink)
Old 04-24-2008, 08:12 PM
Holder350's Avatar
Auto Parts Professional
Originally Posted by machine shop tom
Has nothing to do with engine balance.
tom
Ahh I see,
I have heard some horror stories about getting them mixed up....
I guess the galling is due to the piston being in a bind in the bore.
Light Heavy is the term we always used I guess I just got to thinking that it had something to do with balance.
  #19 (permalink)
Old 04-24-2008, 08:26 PM
techinspector1's Avatar
Wiki Edits: 326
Originally Posted by Holder350
Ahh I see,
The problem is that the rod journal has a fillet or rounded corner at the edge of the crank throw and the rod/bearing also has a chamfer at one side. This chamfer must mate up with the rod journal fillet. If reversed, the rod/bearing will bind up. The piston has plenty of room to move laterally on the wrist pin, so it wouldn't necessarily bind the piston in the bore.
  #20 (permalink)
Old 04-25-2008, 03:01 AM
This doesn't apply to the 4.3. Each rod has it's own journal. There is no larger chamfer on one face of the rod as compared to the other.
tom
  #21 (permalink)
Old 04-25-2008, 05:44 AM
they assembled them wrong!!!...
ask them to accept them with the FEDEX or UPS next day charges collect ...and ship them back FEDEX/UPS next day!!!!
or else come pick them up for re-do...or buy you a tank of gas
if you and they have a bus station close by..."fair chance" you can get them corrected on a single day....
if they have any brains at all...
they will THANK YOU! for catching the error because otherwise they will/would be buying you a whole new motor by showing that wrong assmbled piston/rod to a judge in small claims court!!!!
  #22 (permalink)
Old 04-25-2008, 06:33 AM
The Piston are a Sealed Power 423NP std size. also are the bearing from a V8 fit the 4.3 rod
  #23 (permalink)
Old 04-25-2008, 08:33 AM
Wiki Edits: 326
tom
Thanks Tom, too many 350's in my mind.....
  #24 (permalink)
Old 04-30-2008, 11:42 AM
Crank won't spin update
I got a guy to come and see what he can do with it he took it all back apart oil it all up big time got it back togetter and it spin better
but he think it still to hard so he took the 3 pistons out that was install incorrect and it still on the hard side
the only thing he see is one rod seem to be rubing the side.
right now the crank and the pistons are on the way back to the shop
how hard should this motor spin ? just as a short block
  #25 (permalink)
Old 04-30-2008, 12:00 PM
Double_v23's Avatar
Horsepower Enthusiast
Last journal entry: Finished BMOD001FH
not very hard at all, I would think if you had a torque wrench you could spin it with less than 25 ft/lbs
  #26 (permalink)
Old 04-30-2008, 01:56 PM
Then maybe the rod is bent ? Then should the shop have check for this when they . if the rod is true why is there no side clearance for the one rod?
  #27 (permalink)
Old 04-30-2008, 02:15 PM
Double_v23's Avatar
I guess if the shop didn't get the wrist pin centered on the rod it could cause some side clearance issues or if it was binding in the piston. The wrist pin should move freely side to side as well as rotate freely
267 crank into 350 block 74chevyflat Engine 6 08-26-2006 01:15 AM
Repairing a damaged crank by welding.. Old School Nut Engine 7 05-10-2006 08:05 AM
forged crank question Ratoflic Engine 2 04-18-2006 04:50 AM
I need a Crank!!! traub83 Engine 3 05-11-2004 08:56 PM
engine rebuild query re; crank rotation.. crazy larry Engine 9 08-04-2003 02:03 PM
