Originally Posted by ap72
Did you try the carb with the stock rods in it? With the heat of your area if anything I would expect you to go one step leaner than stock.
Yea, and I'll most likely go back to them.
I noticed a small temp increase after the carb swap so I thought it may be a lean condition. Turns out the temp sensor is jacked up and when changing the carb I hit it and it started reading goofy.
