New digital E curve distributor died - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-17-2008, 08:37 AM
dawg's Avatar
NAVY VETERAN
MSD isnt impressing me lately!
brand new distributor 3 months old
Old 08-17-2008, 08:58 AM
1947 Chevy Coupe
What did you do, pressure wash it? You know that the cap isn't sealed to the disto right? Water will get in if you give it a chance. I would suspect that MSD figures that the unit will be in a fairly dry environment unless the installer takes some action to seal the cap to the base.
Old 08-17-2008, 12:02 PM
redlightning's Avatar
It looks like there is rust on the screws?
Old 08-17-2008, 12:44 PM
dawg's Avatar
NAVY VETERAN
never washed it
just put a new motor in couple months ago.
had problems from day one with the distributor.
Old 08-17-2008, 12:45 PM
1947 Chevy Coupe
Yup, it looks like it was submerged. No board of any kind will survive that. No wonder it packed it in. Fortunately for dawg, MSD can put in a new board and make it like new again.
Old 08-17-2008, 03:01 PM
dawg's Avatar
NAVY VETERAN
thing that gets me is the distributor never seen water?
also there is numerous cold solder joints and the board wasnt coated?
im betting they farm out their assembly work to mexico!
Old 08-17-2008, 03:07 PM
T-bucket23's Avatar
Wiki Edits: 26
It definitely saw some water from somewhere. Those screws are real rusty
Old 08-17-2008, 03:54 PM
40 grey's Avatar
Dusty mayhem
Great. I just put one of these in my small block(chevy)... So far it appears to work fine, but haveing said that I ran out to the garage and pulled the cap. No rust yet. However I live in a very humid and hot climate. And its that way 9 months a year. I removed the 1/4 turn bails that hold down the cap when I installed it. I use the 10-32 screws and tapped holes to secure the cap to distributor body. Perhaps a little dielectric grease around the sealing surface of cap?
Old 08-17-2008, 07:04 PM
1947 Chevy Coupe
That disto has seen LOTS of water. Dielectric grease sounds like it might be a good stop gap until MSD is contacted for comment.
Old 08-23-2008, 10:05 AM
bubbahotep's Avatar
Water damage could be from simple lack of use. Hot and cold, moist storage garage and you got water accumulation. Thats major moisture damage which took some time to rust out the screws and components. Similar to dew on the morning grass.
Its also possible that the unit you purchased was stored (prior to buying it) in a warehouse somewhere that had high humidity. Or even a parts store that had it in a bad area and you bought an already partly destroyed item.
Old 08-25-2008, 05:20 AM
dawg's Avatar
NAVY VETERAN
no when i got it new it was looking great.
only thing I can figure is there isnt a conformal coating on the board.
misfire @cruising speeds MSD digital E curve Distributor dawg Engine 8 07-04-2008 11:35 AM
