New Disc Brakes but soft pedal - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-09-2011, 06:59 AM
I am finally getting aroud to test driving my car after a 3 year resto. I installed a 4-wheel disc brake conversion. The front and master is Classic Performance, and the rear is Right Stuff. It is a power system.
The problem I have always had is the brakes are soft. when I push the pedal it goes almost 3/4 of the way to the floor before the car stops. I have talked to both companies and they have run out of ideas. I have increased the pedal throw as far as I can. I installed a new 1 1/8 bore master. reverse bled all teh lines to be sure there is no air in the lines. The only thing I can think is to put a 2 psi residual valve in the rear lines.
What do you guys think?
Front and rear calipers are single piston. 11 in. booster, 15-18 inches vac from engine. 3/16 lines go to the front calipers. 1/4 lines goes to the split at the rear.
Old 04-09-2011, 09:04 AM
ogre's Avatar
the 'Duracell Project'
usually residual valves are for when you have the mc mounted low.
since you've tried everything else, i would add them.
minimize use of flex lines.
also check to see that all your bleed screws are on top.
Old 04-09-2011, 09:09 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You may need to change the pedal ratio. Or is that what you mean when you said you've increased the pedal throw?
Old 04-09-2011, 09:56 AM
Maxwell007's Avatar
I agree with Ogre. Check the bleeder screw locations first.
What kind of rear calipers do you have? If they are the GM type with an integrated parking brake, there is a trick to adjusting these. I have seen these type calipers cause the same symptoms you are describing.
Old 04-09-2011, 05:47 PM
Yeah they are the calipers with the e- brake. They are a pain in the a** to set and bleed. While I am thinking about it does anyone know a caliper I can put in their place? I don't have the e-brake hooked up anymore anyways.
Yeah they had me check the pedal ratio and they said it was spot on. what would you recommend it be I will check it tomorrow. I don't remember what it was.
Old 04-09-2011, 08:42 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
3.5:1 to 4.5:1 for power brakes is in the area you want to be.
Here's a good place to do a little reading.
http://www.mpbrakes.com/technical-su...igurations.cfm
Old 06-20-2011, 09:31 AM
Hey, I know this thread is a little old, but I just came across it on google. I've been having the same symptoms on my '78 T/A with stock disc/drum setup. I've replaced almost everything with OEM parts (calipers, drums, pads, M/C, lines, booster), and have the same problem. It takes about 3/4 of the pedal's travel to get any real braking power. The pedal should be stock (I'm not the original owner, so I can't really confirm that), so I never considered the ratio.
Did you ever figure out what was going on with yours?
Thanks,
Jim
Old 06-25-2011, 08:48 PM
My major problem was the seal on the back of the booster to the master was cracked. I still have a lil soft pedal but it's better for a low vac engine.
Old 06-27-2011, 10:34 AM
Very interesting, I have fairly low vac as well. Would that cause a soft pedal? I was always under the impression that lower vac would result in a harder pedal because there would be less power assist - is that not the case?
Thanks again for the reply, and I'm glad you sort of resolved your issues.
Jim
Old 06-27-2011, 07:25 PM
I don't think hooking up the booster gave me more brakes. I did a lot of things at once so I am not sure what the fix was. I installed a larger master 1 1/8" Increased the lever throow as much as I can. The other problem I think I have is the rear disc calipers are e-brake calipers and they don't seem to stay tight to the rotor as I would like.
As for you do you have a new prop valve? any residual valves?
Old 06-28-2011, 09:59 AM
ogre's Avatar
installation of a residual pressure valve should fix this.
this is why they are recommended.
for low vacumn applications, i'd use a hydroboost
Old 06-28-2011, 12:03 PM
are you talking a 2 lb for the rear disc brakes? or for the guy with the drum brakes?
Old 07-04-2011, 10:06 PM
This is not really haing so much to do with your problem so much as just my experiences.I use vett type masters on most disk conversions.If the system has rear drum I do a 10lb residual even if master is not low.Also never overlook pushrod adj. (had that one bite personally) to make sure replenish port is uncovering when pedal released.
brake pedal hard then soft but hardly any brakes Wildwestshow Suspension - Brakes - Steering 1 12-24-2010 07:18 PM
Soft Brakes... S10xGN Suspension - Brakes - Steering 13 08-24-2009 01:06 AM
Will a Brake Master Cyl. Designed for Disc/Drum be Adequate for 4-Wheel Disc Brakes? mrwumper Suspension - Brakes - Steering 3 04-16-2009 09:38 AM
79 malibu soft brakes mikes68493 Suspension - Brakes - Steering 5 06-12-2007 08:37 PM
soft brake pedal jum Suspension - Brakes - Steering 5 03-05-2006 07:14 PM
