Hey all;
The doors on my 75 Monte have never closed right because of worn out bushings in the hinges. So bought some and finally got around to installing them yesterday. Pulled the door, pulled hinges, popped the pins out, replaced bushings, installed new pins and reinstalled door. When opening and closing the door, it feels so much better, smoother and quiet
Problem is now, the door sits a 1/2in too low. None of the lines match up, and the window doesn't sit flush to the top. I tried loosening the bolts on the door and use a jack to see if it'll slide up some, but there's no give. I've seen panels where the holes for the bolts are move ovals so you can slide them along the bolt, but these do not.
So the question, how do I align these doors? Feels like it's something easy that I'm missing. Thanks
