Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - New door bushings, now misaligned
  #30 (permalink)
Old 05-08-2013, 12:40 PM
tech69 tech69 is offline
put up or shut up
i like to remove the striker so i can better gauge the changes. you know the door is where it needs to be with no striker and from that point it's very easy to tell if the door shifts up or down/in or out by simply looking at the top of the door as you slowly close it with the striker in. if you bring the door to the striker you are more likely to settle as opposed to making sure it's gonna be latching correctly. either way, the problem will get solved.
