New door bushings, now misaligned - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 05-09-2013, 07:37 AM
david-b's Avatar
Dave is THAT guy
Sadly I won't be at the garage until Saturday, but I will make the adjustments and hopefully be good. Ideally, would like to get the drivers side started. I'll post pics and progress when I get there!
Does anyone know what size the striker hex is? Would like to pick one up before I go there. Thanks
  #32 (permalink)
Old 05-09-2013, 07:48 AM
deadbodyman's Avatar
Wiki Edits: 11
You can buy the whole rack of torks bits for under 10.00 at HF but you can (in a pinch) use vice grips on the head to get it off.
  #33 (permalink)
Old 05-09-2013, 07:56 AM
Wiki Edits: 11
The tool for bending the hinges is "ok" but really you want to move things where they need to be. Let's face it, seldom does the hinge get bent when you are using one of these tools, the weakest point is going to bend, and that isn't the hinge its self it's going to be the mounting of the hinge on the door or the cowl or B pillar or where ever the hinge is mounted. So bending to make the door fit may be long lasting, but it also may be short lived being it was bent for a reason, it is weakened and it will go back same place after a while. So it's sort of a last resort. It's also a great tool for the alignment in that you can loosen the hinge bolts only a little and use this tool with it's leverage to move the door a little.
Brian, You do know this door bending(not hinge bending) tool was made for non- adjustable hinges like for the S-10 and GM trucks ...bending a door with adjustable hinges like the car in the pic is basicly a no-no....and its mostly mis- used to bend a door up when the pins and bushing are wore out to get the door to close again. Its a handy( go too tool) for the S-10 though...
  #34 (permalink)
Old 05-09-2013, 07:58 AM
Wiki Edits: 11
MY BAD.....On second look, thats a camaro (welded hinges)just what its made for...for some reason I thought it was a Regal
  #35 (permalink)
Old 05-09-2013, 08:03 AM
david-b's Avatar
Dave is THAT guy
I absolutely hate Harbor Freight tools. I've broken so many of them over the year... ratchets, sockets, wrenches.... they're just cheap. Prefer to spend a little more money up front to get tools that will last. I have Craftsman tools that my Great Grandfather used. Would like my tools to last like that too. I'll probably just go to Sears and see what they got in a full package like that.
  #36 (permalink)
Old 05-09-2013, 09:05 AM
Exactly, that is what I was saying, it's a no-no. I didn't remember that is WHY they were made, for the weld on hinges.
  #37 (permalink)
Old 05-09-2013, 09:06 AM
I believe it's T-50, but as DBM says, just get the set.
  #38 (permalink)
Old 05-09-2013, 09:09 AM
Good thinking, Harbor Freight is my last resort. Something like the little shorty wrenches, I bought a set to get my headers off and they still come in handy once in a while. Try your REAL parts store in town (not the "McParts" stores) and you will often find quality tools like S&K. Believe it or not Lowes sells Kobalt which is a Snap On tools label. They are really pretty good I have found.
  #39 (permalink)
Old 05-09-2013, 12:31 PM
put up or shut up
might as well get an impact driver too. The kind you hammer to break loose bolts. They come in handy, especially for strikers with the phillips head.
  #40 (permalink)
Old 05-12-2013, 04:32 PM
david-b's Avatar
Dave is THAT guy
Alright so made it out to the garage on Saturday and didn't have the best of luck. I realized that taking off the fender meant also taking off the hood, and it just wasn't going to happen that day. I was able to get a rachet and socket on the bottom bolts on the cowl, and was loosening those and trying to get the door up. However, since the door had to be open to loosen/tighten those bolts, it was hard to jack up the door into place. So after a couple times of doing that, there was still no change.
Then decided to add some shims on the bottom hinge (door side) to get it to push the door out some (I know, was told not to because it's not professional), but is only temporary until I find a body guy. Everytime I take the car out to shows, always run into body guys who want to work on her. So that pushed the door some, and then moved the striker up a little. It fits, not perfect, but much better than before still. I'll work on it some more, but just short on time do to personal stuff right now. You can see in the attachment that it fits decent. If you're looking specifically at the alignment then ya you can tell. But again, just needed it in place where I can drive it for the time being.
As far as the drivers side, it looks like I can do the bottom, but the top the pins go into the door if taking it off, so wouldn't work. Also, that little roller that rolls along the track to where the door opens up half or full way, is nearly off the pin, which explains a lot on the drivers door. So I feel I can rebuild the bottom first still entirely on the car, but will have to take off the top entirely. Hopefully, that all works out. No idea when I'll get to that though.
Bought a full set of the T bits from AutoZone. Was $13 for the set, and much better than what Harbor Freight had. I believe it was a T24 for reference.
Again, thanks for all the help.
/D
  #41 (permalink)
Old 05-14-2013, 06:02 AM
Wiki Edits: 11
WOW ,Its been a long time since I worked on one of those...
To get at the pillar bolts you could try removing the inner skirt...I believe thats a steel one instead of plastic so even that could be a bear...
  #42 (permalink)
Old 05-14-2013, 08:23 AM
/D
If you loosen the top bolts to the cowl as well leaving ONE tight, you can lift up on the door moving the bottom hinge a little and then tighten ONE of the bottom hinge to cowl bolts to check the door. Another method is if you have a slide hammer and can get a grab of the lower hinge to snap it back a little.
With the correct tool it is possible to get those bottom bolts to cowl loose but they don't come cheap.
Snap on Tools s Type Door Hinge Wrench Ratcheting Orange Screwdriver Handle | eBay
  #43 (permalink)
Old 05-14-2013, 09:37 AM
put up or shut up
did I miss something here? why not loosen both the hinge to door bolts and raise it evenly and keep your gap? No twisty wrench?
1966 chrysler newport misaligned steering Rat_Rod_Ho Suspension - Brakes - Steering 1 01-30-2010 02:00 PM
Door hinge bushings? flynbrian48 Body - Exterior 11 11-27-2007 08:57 PM
Badly misaligned timing on belt install Dizturbed One Engine 15 01-22-2007 09:40 PM
misaligned roller rockers? TVR383 Engine 5 05-31-2004 07:17 PM
carrier bearing misaligned cause vibration? catscan4free Transmission - Rearend 1 01-10-2004 02:53 PM
