new drive shafts after 4" lift? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-22-2007, 07:04 PM
dikki706's Avatar
i put a 4" rough country lift on my 83 jimmy. no blocks or body lift, just four new leaf springs and shocks and stuff. it looks like my front and rear drive shafts are stretched to capacity. it runs fine and makes no noises (a little vibration) but i fear if i get into a tough spot offroad and my suspension is put to the test that one or both drive shafts will either split or fall out of the tranny. is this a legitimate fear? they are both two piece drive shafts and i don't want to be stranded.
Old 11-22-2007, 08:24 PM
2NDChance's Avatar
Newbie-but learning
i'm not a 4x4 guy- but you could mark your shafts now at ride hight with a paint marker pen (the junkyard stuff) then use a HighLift style jack to lift the ends of your truck to stretch suspension and mark again. after this process take them apart, measure the difference, then call lift manu. to get advice what to do. at least after this step you know where it's at for specs.
Old 11-23-2007, 08:28 PM
dikki706's Avatar
my buddy told me to quit being a p___y and just go balls out with it. he offered to follow me with a tow strap and pull me home if need be. what he didn't offer was to pay for any residual damage. his solution sounds more fun. you know the old saying "wheel it - wreck it - wrench on it"
Old 11-23-2007, 09:18 PM
does it still have the ten bolt clicker posi in it ?
it will probably spit it out first .
4 inch lifts don't require shafts and rear end tilt spacers to get the pinion up .
did you block the sway bar mounts , it will pull the front housing forward and will spit the bushings out when they get wet and muddy and you get it in a tight spot.
tell your buddy to show you how to run the trails , he might need your truck to pull him out , or is he a p---y ?
get ur - bogged down - done !
Kwik Lift? bigbird Garage - Tools 26 07-27-2008 09:52 PM
how to remove tach drive from distributor ? dastone Engine 2 08-23-2005 07:10 AM
lift = to seat pressure universal? 84Z Engine 1 07-24-2004 06:14 PM
A question about dual lift profile engines. dmc12mk3 Engine 8 06-16-2004 11:31 PM
Need help on installing a 2 post auto lift shockers69 General Rodding Tech 3 11-24-2003 07:59 PM
