-   -   New Driveshaft Noise (http://www.hotrodders.com/forum/new-driveshaft-noise-10862.html)
bjam2 06-01-2003 08:23 PM
Ok u-joint broke driveshaft goes flying, fix, driveshaft comes off on highway a few months later cus i'm guessing it wasn't balanced, new driveshaft off of other el camino (stock u-joints) and now its making a sorta rubbing/squeeking noise that gets fast with the RPM's, so what is the noise and how can i fix it?
Also are these U-Joints gonna break too, cus i'm getting pissed off at this driveline, i'm definitely investing in a driveshaft safety loop, ripped off half my exhaust the last time it went flying around at 70 mph.
jimfulco 06-01-2003 11:08 PM
Sounds like one or more of the U-joint bearings is going dry.
adtkart 06-02-2003 04:21 PM
Definately sounds like U-joints to me. This is a case where I would change both joints at the same time. They are usually about $20.00 each or even less. Worth the extra cost to make sure they are both good. Also make sure you grease them after you put them in.
bjam2 06-02-2003 06:30 PM
It wasn't making this noise on the other car though.
jimfulco 06-02-2003 08:44 PM
Might have been under less strain on the other car. (angles, etc.) Does it have grease fittings?
[ June 02, 2003: Message edited by: jimfulco ]</p>
Mrfixmaster 06-03-2003 06:33 PM
Speaking of angles, are all yours stock? Have you changed rear ends, springs, mounts, etc. Or have you changed anything about the way the engine and tranny mount? If the angles aren't "cancelling" each other out, it could be screwing up your u-joints. <img src="confused.gif" border="0">
garyroushkolb 08-26-2006 12:18 PM
new squeek
I would agree that the u-joint is going away. You have about a week and it'll show you which one. Better to schedule a fix on you time schedule that 1/2 way to work on a rainy day. This happened to me before a date in the olden days.
