-   -   New engine breakin proceedure... (http://www.hotrodders.com/forum/new-engine-breakin-proceedure-74440.html)
smac 11-20-2005 05:34 PM
I ran across an unusual (to me) procedure for breaking in a new engine and it leads me to a few questions.
First, what do you think of this procedure:
http://www.mototuneusa.com/break_in_secrets.htm
and last, if you disagree, what method do you recommend for breaking in a new engine.
Thanks,
Sean
ccnova 11-20-2005 05:47 PM
We used this method on our small block Chevy about 2 years ago and have had great results. Personally I will never do it any other way again. Make sure the entire engine is pre-lubed all fluids are correct timing is set etc on initial start-up and do as it says. Good luck, ccnova
tornado-tech 11-20-2005 06:30 PM
I agree. That is how I break them in "Break them in like you are going to run them". My 1st mud run was the day after I put my motor in and this was a 4-run 200' mud drag. The motor was run just long enough to set total timing and adjust the carburetor the night before (maybe 3-4 minutes). People thought I was crazy to do this but this is the way I break in new or rebuilt motor since I been racing one way or another.
Rick WI 11-20-2005 06:35 PM
Give break in the same consideration you did upon assmebly or in slaving away earning all that cash to purchase the motor. Lot's of little hiccups can be caught on a proper break in that otherwise can turn into a disaster.
