New engine breakin proceedure... - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-20-2005, 04:34 PM
smac's Avatar
I ran across an unusual (to me) procedure for breaking in a new engine and it leads me to a few questions.
First, what do you think of this procedure:
http://www.mototuneusa.com/break_in_secrets.htm
and last, if you disagree, what method do you recommend for breaking in a new engine.
Thanks,
Sean
Old 11-20-2005, 04:47 PM
ccnova's Avatar
We used this method on our small block Chevy about 2 years ago and have had great results. Personally I will never do it any other way again. Make sure the entire engine is pre-lubed all fluids are correct timing is set etc on initial start-up and do as it says. Good luck, ccnova
Old 11-20-2005, 05:30 PM
tornado-tech's Avatar
I agree. That is how I break them in "Break them in like you are going to run them". My 1st mud run was the day after I put my motor in and this was a 4-run 200' mud drag. The motor was run just long enough to set total timing and adjust the carburetor the night before (maybe 3-4 minutes). People thought I was crazy to do this but this is the way I break in new or rebuilt motor since I been racing one way or another.
Old 11-20-2005, 05:35 PM
Give break in the same consideration you did upon assmebly or in slaving away earning all that cash to purchase the motor. Lot's of little hiccups can be caught on a proper break in that otherwise can turn into a disaster.
ENGINE BALANCING NAIRB Engine 22 01-23-2016 01:44 PM
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
1973 Chevelle Malibu Engine Rebuild (pics 56k no) Malibu73 Hotrodders' Lounge 39 11-04-2008 12:37 PM
Build for Hp or Torque? Venturat Engine 76 09-23-2008 10:22 AM
question for any engine builders out there mopar72 Engine 7 11-06-2005 03:06 PM
