new engine breakin question - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-18-2010, 10:10 AM
40forddgc's Avatar
Just installed a rebuilt 350 cu inch chevy. It has break in oil. Should I expext to consume any oil in initial breakin period? Thanks...
Old 04-18-2010, 10:22 AM
breakin
yes almost always you will notice a little oil useage at first that is totally normal, make sure when you start the engine you have the zinc brake in suplement in the oil you can buy it at napa or any perfomance shop, they took zinc out of oil a few years ago that what helps your brake-in when you first start the engine, also hold the engine at approx 2000-2500 rpm for approx 20 min, all this is very emportant on brake in good luck
Old 04-18-2010, 11:13 AM
40forddgc's Avatar
break in
Thanks. What would be normal usage? I used a half quart in the first 300 miles.
Pinging on 03 Chevy 5.3 Engine in Suburban bry21317 Engine 42 10-02-2011 07:35 PM
383 engine tapping and oil burning- weird RowShan Engine 15 10-10-2009 05:07 PM
say you have a THOUSAND horsepower engine..... (technical engine question inside) lowROLLERchevy Engine 14 02-24-2007 08:26 AM
Engine Mount Question Nightfire Hotrodding Basics 5 04-01-2004 10:15 AM
Another Engine Swap Question 7skylark6 Engine 5 02-06-2004 01:17 PM
