Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - New Engine build, is cam gear one tooth off?
Old 12-14-2003, 05:05 PM
Dradee's Avatar
Dradee Dradee is offline
What problem?he says it starts and runs fine,like everyone said above dont worry about what timing light says set it where it runs best.When you use new timing cover and damper you have to make the true timing marks on them if you it to correspond to the timing mark on the damper and cover.
