Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - New Engine build, is cam gear one tooth off?
Old 12-14-2003, 10:09 PM
Dradee's Avatar
Dradee Dradee is offline
The carb idle and initial timing work together,if you had your initial timing 'really' that high you would be backing the idle and mixture screws way down to get the idle down to around 800rpm and that would be a sign of too much advance not to mention the pinging and the hard starting.
