New Engine Combo - Your Opinions - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 01-13-2008, 03:39 AM
For those interesed, here are a few pics of the heads.
  #17 (permalink)
Old 03-22-2008, 08:41 PM
Last journal entry: dash mods
  #18 (permalink)
Old 03-23-2008, 08:46 AM
Probably up and running, but do you have a pic of the guide boss more visible than in the above pic?
  #19 (permalink)
Old 07-14-2008, 07:57 PM
J.D J.D is offline
Originally Posted by DoubleVision
200cc heads are too big, it'll be rather soggy in the lower RPM ranges. 180 would have been far better. the smaller 600cfm carb will make up for some of it, but not much. Since you dont know for sure your rear gear I'd find out, as it will be a big influence on how it performs. I always use GM head gaskets that are .028 in thickness, the 64cc chambers will give you a ratio somewhere in the 9:1 area even with the thin head gaskets depending on how far down in the bore the pistons are. rest of the combo looks good, but I think you have a bit too much head for it.
If he shaved the heads and uped the compression would that not help for the large runners?
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 11:00 PM
Valve Lash adjustment hiball Engine 36 05-11-2009 11:12 AM
Anything wrong with this engine combo?? Scott2112 Engine 6 03-05-2007 10:53 PM
Opinions requested from Engine Builders jleeheat Engine 24 02-06-2007 09:31 PM
engine tranny combo buffulohunter Engine 4 01-22-2007 08:05 AM
