Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - New Engine Combo - Your Opinions
Old 01-10-2008, 12:12 PM
454C10 454C10 is offline
Yes, it will make a good mild cam. However, it has very aggressive lift rates which often can cause lobes to go flat.
When selecting the cam, the intake/exhaust flow ratio should be considered. A stock GM cylinder head typically has a poor I/E ratio (65 to 75%) so it does well with a cam with more exhaust duration, like the one you have. However, after market heads tend to have good I/E ratios (>80%) so a cam with the same intake and exhaust duration should be used.
Do a search on this site for "flat lobes" or "bad cam" or the like and see how many are voodoo or xtreme cam grinds.
