new engine falls on it's nose - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-05-2011, 07:25 AM
Recently purchased a new GMPP 350 carburated engine for my chevelle and am experiencing a big hesitation on accelerating. From a dead stop pulling away from stop it seems to fall on it's nose for for a second then recovers but this is very annoying and frustrating. It's probably something simple but I'm no great mechanic especially if it's involved with the carb (new holly that came on engine). can anyone suggest suggest the problem area I should focus on....This engine was a totally complete GMPP crate engine and I haven't twinked it since installing in car.
Old 06-05-2011, 08:04 AM
GMCBEAST's Avatar
I'd start simple, especially with a new running motor. Do a full sweep of your ignition system. Make sure all plugs are gapped properly, connections are good from battery to ignition, plug wires are snapped and in correct location and timing is accurate for your setup. If all that checks out then fool with the carb. Hope this helps.
Old 06-05-2011, 08:29 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Might be the accelerator pump circuit. Holley's instructions are on page 6 and 7 HERE.
If the accelerator pump checks out OK, see if adding initial timing will cure the hesitation. Just don't exceed the max total timing in the process of adding initial timing.
Old 06-05-2011, 08:31 AM
Sixguns's Avatar
symptoms as yours are most always the accelerator pump circuit in the carb, you can adj the cam that moves the pump arm, it should have three positions of adjustment,and adj the pump arm so there is no play, a third adjustment will be the size of the squerters,,but those are the least likely cause. I will sugest you get the tuning CD from holley, it will be a huge help to you.
Old 06-05-2011, 11:54 AM
cool rockin daddy's Avatar
X3 on accelerator pump. Gotta tune that puppy!
Old 06-05-2011, 11:57 AM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
X4 on accelerator pump, and a good tune put on it.
Cole
Old 06-05-2011, 12:35 PM
Looks unanamous... Guess I will focus on the accel pump once I can return to work on car...thanks to all for your thoughts...
97 s10 falls on ite face at 1/4 throttle 70gtx Electrical 4 05-18-2011 03:13 PM
700r4 falls out of gear 86 k20 Transmission - Rearend 1 09-30-2010 08:55 PM
350 falls on face when floored bobyell Engine 18 09-14-2009 04:44 PM
Engine falls over above 5000rpm Pinko351 Engine 16 04-30-2007 04:00 AM
Window falls down when i roll it up or down sometimes. 72Nova Interior 6 01-25-2003 03:11 PM
