Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - New engine has to come apart
Old 10-27-2006, 11:26 AM
cj11l cj11l is offline
Engine oil consumption
Guys, if it were me, I would do a few diagnostics first before tearing anything apart.
One quick check would be to do a cylinder leak-down test. Get the piston at TDC on compression stroke, fill the cylinder with air using fitting in the plug hole and listen for escaping air. If you hear air leaking into the pan, well that means a problem with the piston/ring. Leaking into intake/exhaust manifolds, probably valves.
Most people check compression only, which is ok, but that really doesnt pinpoint the problem area.
Chris Laarman
Ottawa Engine and Performance
