New engine, horrible grinding sound....anyone want to make a bet - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-29-2004, 08:18 PM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Hey all,
I got the exhaust on the 84 GMC builder pickup today and got to take it for a test drive. In normal fashion for me, something is hosed up.
The truck is a short wide with 3 spd standard trans and a new 350 my brother and I just finished building. I got the cam broken in and everything was going well. The first time we got in the throttle hard today something let go. We drove it home and everythings seems fine except a nasty grinding/knocking noise coming from bell housing area. It almost sounds like a bolt backed out of the pressure plate and is attacking the bell housing.
Anyone want to wager a bet on what the problem is? I am so tired of things breaking.
Chris
Old 10-29-2004, 08:22 PM
killerformula's Avatar
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
starter rubbing on flywheel
Old 10-29-2004, 08:24 PM
poncho62's Avatar
Wiki Edits: 5
That would have been my guess too, but since it's taken, I will say ...throw out bearing.
Old 10-29-2004, 08:30 PM
Ghetto Jet's Avatar
current hot rod: CTS-V
Last journal entry: Lets Get Started With the Improvements
Killer didn't your Formula make the same noise after you got the 383 running?
Old 10-29-2004, 08:32 PM
Wiki Edits: 3
yup.
Old 10-29-2004, 08:33 PM
TurboS10's Avatar
Wiki Edits: 2
Throw out bearing is brand new. I thought a about the starter having an issue, but the engine has run for ~20 minutes with no issues. As soon as it started to rev under load the problem showed up.
Chris
Old 10-29-2004, 08:36 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
Does the noise change when you press the clutch in?
Old 10-29-2004, 08:41 PM
Wiki Edits: 3
Chris
Mine had no issues to start as well, after the bendix gets worked a few times it acted up...
New starter isn't it?
K
Old 10-29-2004, 08:43 PM
TurboS10's Avatar
Wiki Edits: 2
The noise is the same with the clutch in or out, in gear or out. The starter is not new. It was on the 6 banger that I took out of the truck. It seems to work beautifully.....
Wiki Edits: 3
well I'm all out of ideas then!
K
Old 10-29-2004, 08:47 PM
TurboS10's Avatar
Wiki Edits: 2
I am not saying it is not the starter. I have never had one hang in on the flywheel, but I have heard it can happen. It does not make any bad noises while cranking that I can tell. I have not messed with it too much. I will probably pull the dust cover tomorrow and take a look.
Old 10-29-2004, 10:42 PM
RCastle's Avatar
Come Home Safe Soldier
Last journal entry: Headers
Had a nasty sound once on my 75 Chevell Landau.It was an automatic and the trans to engine block bolts had backed out enough and put the flywheel and converter in a bad bind.I know you have a manual but there is another possible place to look after the starter.
Old 10-30-2004, 05:34 AM
schnitz's Avatar
Last wiki edit: Building a new shop
Last journal entry: Christmas 2008 came early!!!
Wiki Edits: 54
I'm leaning on the Rcastle side of things. My buddy had a late '80's s-10 Blazer that sounded like that too. The torque converter bolts had worked loose. Almost sounded like a rod knock or a rear of the engine main bearing. Is it possible that the release fork is wore on the ballstud? My truck made some weird noises when that happened as well. Good luck.
Old 10-30-2004, 08:07 AM
troy-curt's Avatar
Shop Owner And Troll Hunter
Is the dust cover rubbing the flywheel? Take it of and try it.
Troy
Old 10-30-2004, 08:14 AM
NAIRB's Avatar
Chris,
With the bad luck you've had lately, I hope it's just a bolt backed out.
