new engine knocking
Help! I am new to this... I am trying to install a newly rebuilt sbc 350 engine into my 67 el camino. The engine came from a shop who apparently built it from "extra" parts. What I know (or so they said): 1995-2000 gm crate engine block (casting numbers verify) cleaned, checked and honed by machine shop - Gen1 with one pc rear main seal, "Hecho en Mexico" 72cc heads, no work done, came from a newly rebuilt engine cust changed mind on heads took them out before driving (numbers verify and look new), stock vette 5.7 rods, stock crankshaft from crate motor (casting numbers say is forged??), new flat top pistons (speedpro), new "big" comp cam hydraulic flat tappet don't have specs, can't get - sounds like a MONSTER when running, new push rods, new Harland Sharp 1.5 rockers (with stud girdles), and new TCI flexplate... I know more but I think this gives you what you need for this question -
We got everything hooked up, mechanic friend adjusted rockers, fired engine up, minor adjustments to get it to idle, then warmed it at idle. 50# oil pressure, 160 degress warm. Then it started a knock. A bad knock low in the engine. Cut it off, pulled engine and took back to shop we bought it from and they told us "could be cam is too big or rocker arms aren't made for this motor." It's under warranty and they agreed to make it right and are sending it to machinist but question is - wouldn't that have to be a bearing? And if so would a bearing be affected by the size of the cam or rockers? Also if it was a bearing is there a danger of block damage now? I just don't want them to get the knocking to go away then us have trouble after the warranty period. Also I read somewher on a post that a cracked sark plug might cause that sound??? When we took plugs out they were a little oily, dark, and one of them was cracked... Any help or opinion is MUCH appreciated. Sorry for the long story I just started with what I figure you might ask. Newbie mechanic in despair |
Hmmm.
Well, at least they warranty'd it. Lots 'o' variables here as you could imagine. To quote you: "- wouldn't that have to be a bearing?" Quite possibly. A 'knock' could be a flat cam lobe, but it has more of a 'clank' sound. A rod has a very characteristic 'thud' deep in the engine as you describe. I think what they said, "could be cam is too big or rocker arms aren't made for this motor." is bull puckey. Best of luck. |
Are the rest of you guys seeing what I am here? -No mention of a cam break-in procedure. I'm going with wiped-out cam lobe(s). -Jim... |
Doesn't mention anything about what oil was used or if any zinc additive was added. Warranty may not cover due to improper cam break-in. Cam too big??? BS statement for sure. |
depending on the piston pin location in the particular flat top pistons (how far in the hole at TDC with the Vette rods) and the amount of lift on the "monster" cam and the reliefs depth in the pistons and the rocker ratio,,,
he wants to confim the valves are not hitting the pistons ... he gave you just one example of many items to be measured and checked.... (likely/possibly based on your choice of wording to describe the problem sound????) if it is indeed a "monster" cam duration, (2500+rpms operating range, 8-10Hg idle at 1,000+,,,etc) you do need better heads/higher stall convertor/lower rear gears/probably a MSD box/headers/different intake/etc= alot more $,$$$'s!!! now is the time to decide if a more street friendly grind duration and lift cam is "maybe" a better choice.... |
break in
Yea guys I too thought of the cam not being broke in when i heard this, but its just like second nature to me, and just has to be a must for anyone else building an engine. If not it will fail
If I had to GUESS over the internet, the first thing I would do is drop the pan and see if the rods bolts are torqued to spec.
Alot of cheapie rebuilds are done without replacing rod bolts, I've seen more than one engine come apart with a rod knock that had the builder figuring he forgot to torque the rod bolts, but it was actually rod bolt stretch..... I can't see a cam wiping out that fast and that drastically, but if it did the oil filter should be PACKED with debris IMO..... Drop the pan, cut the filter and go from there...? |
| SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine | Oldsmolac911 | Hotrodders' Lounge | 50 | 01-12-2011 10:00 PM |
| 53 Packard Clipper Engine Swap? | 53packard | Engine | 16 | 07-06-2010 04:32 PM |
| Build for Hp or Torque? | Venturat | Engine | 76 | 09-23-2008 10:22 AM |
| Why high RPM's on the oval tack? | steveyb4342 | Engine | 25 | 05-23-2007 07:50 AM |
| engine developed knocking sound | sune | Engine | 6 | 09-06-2004 02:40 PM |
