New Engine Oil Priming - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-21-2010, 03:13 PM
I have a new SBC crate engine with a hyd roller cam and hyd roller rockers. I have been trying to prime the engine with oil using a Summit Racing priming tool made for this engine. After runing the oil pump with the priming tool two seperate times I am only getting oil in two or threes rockers on each side. And the oil is only oozing out of the rockers not shoooting out like I thought it should. I don't want to turn the engine over without oil in all of the bearings and rockers!
I would appreciate any ideas or experience other people have had.
Thanks, Dick
Old 11-21-2010, 03:18 PM
david-b's Avatar
Dave is THAT guy
Thanks, Dick
Is the drill that you're using fast enough to get the oil all the way up there? Low RPM drills I hear won't get oil all over evenly
Old 11-21-2010, 03:21 PM
NOlowrider's Avatar
US Navy-Retired
What I do is prime it like you did, then rotate (by hand) the crank 1/4 turn at a time and prime it again until the crank has gone a full 360*. That allow all of the oil journals on the crank to align with the main bearing journal on each particular crank bearing.
The amount of oil will depend on the speed at which the oil pump is turning. I use a modified dist with a hand drill.
I start at TDC.
Old 11-21-2010, 04:13 PM
T-bucket23's Avatar
Wiki Edits: 26
Priming is important in all cases but not 100% critical with a roller. As mentioned already, turn the crank 1/4 turn and you will most likely see the rest of the rockers show oil. You also need to use a real strong drill to get any volume.
Chet
Pinging on 03 Chevy 5.3 Engine in Suburban bry21317 Engine 42 10-02-2011 07:35 PM
oil change- step by step instructions for women and men Fireball Hotrodders' Lounge 38 08-30-2008 07:39 AM
Oil Priming - Chevy V8 - No Oil to Lifter Bores - Help leejoy Engine 4 03-09-2008 10:55 PM
Oil filter Super Magnets? Jag Daddy Engine 59 02-01-2006 07:36 PM
Should I change my oil? 48Man Engine 2 01-29-2003 07:28 AM
