We're winning the case!
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 11-06-2009, 02:14 PM
cutthroatkid cutthroatkid is offline
cutthroatkid's barnstar
Wiki editor
Last wiki edit: Need more horsepower for my 305
Wiki Edits: 2
new engine please help...
Ok so I have a company that makes race engines building me a 350 bored 30 over with flattop pistons a mild cam&a double roller timing chain &I was gonna use my 58cc 116 305 heads...I've talked about this alot&I know they raise the compression alot&they have bad airflow what I'm wondering is am I gonna be able to run pump gas?I thought they were poerted but someone told me today they wernt,I can have a 3angle valve job done for free but will they be good to put on there?...I'm not buying anyother heads so PLEASE don't even mention it.The guy who is building my motor said he would put the heads on the intake&carb dist oil pan etc set the timing&put it on the dyno all for 230 so I don't know if I should have him do that or if I should do it myself I'm concernd about the heads
Old 11-06-2009, 02:23 PM
zildjian4life218's Avatar
zildjian4life218 zildjian4life218 is offline
Bowtie Guru
why are you worried about the heads if you aren't considering swapping them out for something better? bolt them on and run it.
Old 11-06-2009, 02:28 PM
Wiki editor
Wiki Edits: 2
Well if you read I stated I was worried that I wasn't gonna be able to run pump gas&I was looking for an answer to that
Old 11-06-2009, 03:14 PM
DoubleVision's Avatar
DoubleVision DoubleVision is offline
2nd Gunman On The Grassy Knoll
Run the 305 heads, we will teach you how to tune it so it will run on pump gas. We`ve already did this same combo in the past and made it work so I am sure we can teach you how to do the same. I think you`ll be surprised at it when it`s finished.
Old 11-06-2009, 03:18 PM
Wiki editor
Wiki Edits: 2
Yhanx double vision I can allways count on you...so you think I should pay the 230 to have him put it all on there or should I do it myself?
Old 11-06-2009, 03:25 PM
old76c10's Avatar
old76c10 old76c10 is offline
all jacked up on mountain dew
for 230 more and he is going to put the top end on and put it on the dyno id say let him do it....that way when you get it,it should be tuned pretty good if he is going to dyno it
Old 11-06-2009, 03:29 PM
Wiki editor
Wiki Edits: 2
That's what I was thinking...he told me I could be there when he did it&also I've had a lot of problems with my carb is a holley with non adjustable floats he said he'd change the bowls for me for free
Old 11-06-2009, 04:05 PM
Wiki editor
Wiki Edits: 2
Old 11-06-2009, 04:08 PM
Being you`ve had trouble and etc then sure, let him do so especially being the extra work is for free.
Old 11-06-2009, 04:15 PM
blue54's Avatar
blue54 blue54 is offline
The knowledge learned while tuning an engine on a dyno is irreplaceable. You can change the tune up and see the results as quickly as starting the engine. Good luck.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "new engine please help..."
Build for Hp or Torque? Venturat Engine 76 09-23-2008 10:22 AM
Engine alignment ssmonty Engine 9 07-22-2008 10:10 PM
SF oil???? n-gin Engine 6 07-09-2008 01:37 PM
the history of chevy v8's savman1 Engine 30 01-25-2008 01:02 PM
Why high RPM's on the oval tack? steveyb4342 Engine 25 05-23-2007 07:50 AM
