new engine priming - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-21-2011, 01:49 PM
Jason7504's Avatar
new engine priming
I just primed my new engine but I can't get it running for a little. Will i need to prime it again later on before i get it running? how long does the priming last?
Old 03-21-2011, 03:02 PM
boatbob2
priming engine
Hi,i dont know how long the priming will last,im assuming,you are talking about priming thru the distributer hole,(engine oil) when i have an engine on the stand,i re-prime it about every 2 weeks,as well as rotate the engine,i also squirt a little oil in the cylinders.
Old 03-21-2011, 03:05 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi
Since this is a new engine I'm assuming it has some kind of paste lubricant on the moving parts, that is all that's needed while your waiting to start it for the first time. Just prior to start up prime it, fill the carb, check that everything else is set so it will start right up.
Rich
PS If you continue to prime it, you'll wash off the paste lube that's there, & not have any for when you start it.
Old 03-21-2011, 05:52 PM
Jason7504's Avatar
Originally Posted by richard stewart 3rd
Hi
Rich
you mean assembly lube? then yes it does. Well i probably can't start it up for atleast a few weeks. Will this priming suffice?
Old 03-21-2011, 06:00 PM
Yes
Rich
message to short
Old 03-21-2011, 06:03 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
X2 you will be fine just prime it up before start up.
Cole
Old 03-21-2011, 06:34 PM
Jason7504's Avatar
Cole
so I gotta reprime it?
Old 03-21-2011, 06:36 PM
eloc431962's Avatar
Wiki Edits: 37
Yes i would to be on the safe side. JMO I mean it don't take very long better safe then sorry. IMHO
Cole
New Engine Oil Priming raps1934 Engine 3 11-21-2010 04:13 PM
priming engine SBC sexypizzaman Engine 8 06-09-2008 02:58 PM
Priming a new engine savman1 Engine 12 09-14-2005 04:13 PM
Engine Priming MI2600 Engine 1 08-18-2003 07:23 PM
priming the engine oil MardyMar Engine 3 05-02-2003 06:57 PM
