Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - new engine, roller cam break in ??
Old 02-22-2005, 08:18 AM
x007's Avatar
x007 x007 is offline
Supercharged T/A
Originally Posted by Rick WI
You still need to seat the rings and change the oil and filter after the first 1/2 hour.
Even with a roller setup we still break in the motor on the dyno the same as a flat tappet, for 1/2 hour running motor at 2200-2500 RPM with light load monitoring water temps and oil pressure. Drain oil, cut and inspect filter.
ok then , i will not take a chance i will do the breaking as usual...
