-   -   new engine, roller cam break in ?? (http://www.hotrodders.com/forum/new-engine-roller-cam-break-58676.html)
x007 02-21-2005 04:42 PM
Hi all,
Does i need any breakin for an engine whit a roller lifter/cam ?
I have my brand new 410sbc supercharged ready, already started it
couple of sec. but not sure if the cam need any breakin procedure like
standard cam ?
:D
SkyMan9600 02-21-2005 04:48 PM
I think you need to run it "nicely" for a little while before romping on it with a new roller cam, but I don't know... I would like to know the answer to this also guys...
BOBCRMAN@aol.com 02-21-2005 04:49 PM
As long as everything is well lubed on startup. There is no actual break in on a roller cam.
lluciano77 02-21-2005 04:50 PM
You don't need any break in with a roller cam. Just make sure everything is safe and drive it.
357f-150 02-21-2005 05:19 PM
No need to break in the roller camshaft but being a new engine, some people like to take certain steps to ensure the rings seat properly, depends on what your using, your call on that one. Good luck
strikingthematch 02-21-2005 05:20 PM
No wonder all the new cars use them lol. Ahh the wonders of of modern tech.
Chris
lluciano77 02-21-2005 05:21 PM
As long as the lifters aren't worn out, you can reuse old roller lifters on a new cam too.
x007 02-21-2005 06:40 PM
So i can assume no break in is required on the engine then...
For sure i will run some miles on it before cranking it :thumbup:
thanks,
Rick WI 02-21-2005 07:18 PM
You still need to seat the rings and change the oil and filter after the first 1/2 hour.
Even with a roller setup we still break in the motor on the dyno the same as a flat tappet, for 1/2 hour running motor at 2200-2500 RPM with light load monitoring water temps and oil pressure. Drain oil, cut and inspect filter.
x007 02-22-2005 08:18 AM
ok then , i will not take a chance i will do the breaking as usual...
Thanks..
