Does i need any breakin for an engine whit a roller lifter/cam ?
I have my brand new 410sbc supercharged ready, already started it
couple of sec. but not sure if the cam need any breakin procedure like
standard cam ?
I think you need to run it "nicely" for a little while before romping on it with a new roller cam, but I don't know... I would like to know the answer to this also guys...
No need to break in the roller camshaft but being a new engine, some people like to take certain steps to ensure the rings seat properly, depends on what your using, your call on that one. Good luck
You still need to seat the rings and change the oil and filter after the first 1/2 hour.
Even with a roller setup we still break in the motor on the dyno the same as a flat tappet, for 1/2 hour running motor at 2200-2500 RPM with light load monitoring water temps and oil pressure. Drain oil, cut and inspect filter.
ok then , i will not take a chance i will do the breaking as usual...
Thanks..
Related Threads
Hot Rod Forum
2.2M posts
175.7K members
Since 2001
