New EZ EFI setup or not? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-30-2010, 11:55 PM
Hi, all, I am going to be making changes to my 1978 Camaro I recently purchased. It currently has a 2 barrel carb. i am going to replace the intake with an Edelbrock Performer II intake. I am trying to decide should I use a spare Rochester Quadrajet I have from another 350 in my garage, of purchase an Edelbrock carb to match the intake. I am also thinking about setting up my engine with one of the new EZ-EFI systems. I know I will have to setup a new Electronic fuel pump. I am concerned with being able to shut my hood. I know with an Edelbrock Perfomer II intake, I will need an adapter to mount the Rochester carb, And not sure about the EZ EFI, but if I order a Edelbrock carb, then I may be able to shut my hood without problems.
Old 05-31-2010, 12:15 AM
techinspector1's Avatar
Wiki Edits: 326
HOOD??? We don't need no stinkin' hood.
Bolt an RPM or Stealth intake on it if you want to make power.
Old 05-31-2010, 06:41 AM
RippinRon's Avatar
I would stick with a carb and save your pennies for a port injection setup if you're going with the fuel injection route.
Old 05-31-2010, 02:09 PM
cool rockin daddy's Avatar
Why? Everything I have seen and read says the EZ-EFI is the real deal up to 600. Tunes itself and learns everytime you drive it. Oh, by the way, they offer it for multi-port deals now. Inglese now offers a old style fuelie unit with 8 stacks controlled by Fast EZ-EFI controller.
Old 06-01-2010, 10:06 AM
RippinRon's Avatar
I dont believe the tune itself bs. But if your going to inject fuel from the top you might as well use a carb.
Old 06-01-2010, 10:14 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If by a "Performer II" you are talking about a Torquer II, I hope I can convince you to reconsider. That intake is an open plenum design that really doesn't perform well, compared to a Performer or EPS intake.
If you have a good Q-jet that has a tight primary throttle shaft, I would w/o hesitation use it on your '78 with a Performer intake or a Performer RPM if you plan on additional mods in the future like headers, cam, better heads, etc.
How's you son liking the '80?
Old 06-01-2010, 03:32 PM
Well, gosh, Ron. What was I thinking. You don't believe it so I guess that's it then. Doesn't matter that FAST is baniking on that particular feature, hence the EZ part. Guess it doesn't matter that an independent source pur it on an engine on the dyno after a 2 hour dyno thrash dialing in a Holley and after bolting it on and making three dyno passes the EZ unit had dialed in the same air to fuel ratios and was making more hp and torque down low. But like you said, you don't believe it so that is good enough for me.
SBC Power Steering and Alternator Setup Advice eric866121 Engine 1 06-15-2009 04:17 PM
The Best And Most Power Setup For My Street 73 Impal Conv. W/ Sbc400 STUFF D Hotrodding Basics 2 04-20-2009 01:21 PM
My 1990 Bronco XLT 351W EFI help... Tecchie Engine 6 02-06-2009 06:37 AM
Is my Torque Converter too big for my setup ?? 74NovaRat Engine 15 02-01-2005 08:23 AM
All a matter of timing with BBC and an EFI? vernw Engine 13 01-20-2003 04:26 PM
