Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - new front brakes sticky
Old 05-02-2004, 08:11 PM
poncho62's Avatar
poncho62 poncho62 is offline
Wiki Edits: 5
If you pushed the piston all the way in, there should be a little space between the pads and rotor. This closes up once you step on the pedal the 1st time.
Is both sides the same?...maybe you have the wrong pads, but I don't think so, if they fit.
By square, I mean that they are straight....nothing is bent, is it?
