new front end width - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-12-2005, 11:12 AM
deathbypontiac's Avatar
New Member
new front end width
i am measuring for a new straight axle front end and was wondering what width axle to get to fit under a 1930 model a with fenders. i will be using 37 style spindles and disc brakes. if any one can give some suggestions that would be appreciated.
Thanks
Old 12-12-2005, 02:50 PM
Most of the chassis guys use a 46 inch ( center to center ) axle under a Model A.......and a lot of 32's. BUT... I have a 48 inch one under my 32 ( both of them ).....
You can see from the above photo that I have plenty of clearance but a 32 is a little wider than a Model A..... and my rims are not reversed so they do not hang out far from the wheel mounting flange.
I would play it safe and get a 46 inch.....
Front end mock up shows some problems, cut n weld or frame shop? Ripped Body - Exterior 9 11-26-2005 07:03 PM
Got 39 Poncho, have front end questions rwruther Suspension - Brakes - Steering 0 05-23-2004 02:32 PM
Mustang II front end Question horvath Suspension - Brakes - Steering 35 03-02-2003 04:08 PM
is there any front end alignment people out there? IHAVECHEVYPARTS Suspension - Brakes - Steering 5 11-26-2002 07:10 PM
Tables of rear end and front end dimensions willys36@aol.com Transmission - Rearend 1 08-21-2002 05:33 PM
