-   General Rodding Tech (http://www.hotrodders.com/forum/general-rodding-tech/)
-   -   New Fuels (http://www.hotrodders.com/forum/new-fuels-228584.html)
Alaska_Man 01-19-2013 03:06 PM
New Fuels
Can anyone tell me about these new fuels? E85, E15 and a new one in Calif. E10. Good, bad or indifferant.
vinniekq2 01-19-2013 07:35 PM
contact 76 direct.they will fax a tonne of info to you.
41 kustom 01-20-2013 05:52 AM
Fuels
They suck!!!!!!!!!
LATECH 01-20-2013 06:34 PM
Most motor fuel today is "enhanced" with ethanol, to a maximum amount of 10% ...legally. Its purpose is to oxygenate the fuel so it burns leaner and cleaner, especially in winter. It does work, it is effective, but mileage suffers a bit. Also cold weather causes a decline in mileage as well.
Not sure of E15 , havent heard of it.
E 85 is 85 % ethanol, the 15% of gasoline (petrol base)is to aid in cold start of the motor.
Ethanol is pretty destructive to fuel system parts.
It can be used to run a high compressio engine though, like 12 -14 to 1 compression, as it is alcohol and it works better with high compression.
Sux...its a matter of intended use.
I wouldnt buy a vehicle that runs on "flex fuel" or E 85 , but i would build a street machine with High CR and run E 85 in a minute. Trouble is , it isnt readily available every where.
Using the correct fuel system components with correct metalurgy is absolutely necessary to keep the fuel system from literally disolving.
tnovot 01-24-2013 07:37 PM
E15 is just what it says and has 15% ethanol or 1/2 again as much ethanol as E10. Corn producers here in the Midwest pushed for 15% for all vehicles but hotrodders, gearheads, some equipment producers, and other car folks made a good case for damage to older vehicles so EPA approved it for newer cars - those built after 2007 or 2009 - can't remember which.
We can still find a few stations here which sell ethanol free gas but they are getting fewer so I buy it to support them whenever I am near one.
Pure-gas.org will show you locations of ethanol free fuel in your state.
Terry
