New Fuels
Can anyone tell me about these new fuels? E85, E15 and a new one in Calif. E10. Good, bad or indifferant.
contact 76 direct.they will fax a tonne of info to you.
| The Following User Says Thank You to vinniekq2 For This Useful Post: | ||
Alaska_Man (01-20-2013) | ||
Fuels
They suck!!!!!!!!!
| The Following User Says Thank You to 41 kustom For This Useful Post: | ||
Most motor fuel today is "enhanced" with ethanol, to a maximum amount of 10% ...legally. Its purpose is to oxygenate the fuel so it burns leaner and cleaner, especially in winter. It does work, it is effective, but mileage suffers a bit. Also cold weather causes a decline in mileage as well.
Not sure of E15 , havent heard of it. E 85 is 85 % ethanol, the 15% of gasoline (petrol base)is to aid in cold start of the motor. Ethanol is pretty destructive to fuel system parts. It can be used to run a high compressio engine though, like 12 -14 to 1 compression, as it is alcohol and it works better with high compression. Sux...its a matter of intended use. I wouldnt buy a vehicle that runs on "flex fuel" or E 85 , but i would build a street machine with High CR and run E 85 in a minute. Trouble is , it isnt readily available every where. Using the correct fuel system components with correct metalurgy is absolutely necessary to keep the fuel system from literally disolving.
Fact is stranger than Fiction Last edited by LATECH; 01-25-2013 at 02:54 PM. |
| Recent General Rodding Tech posts with photos |
| Running new fuels | Middleagecrazy | Hotrodding Basics | 3 | 11-02-2012 10:26 AM |
| Sunoco Leaded Racing Fuels | adam83 | Hotrodding Basics | 8 | 09-14-2011 09:11 PM |
| Alternative fuels....way of the future? | joe350s10 | Hotrodders' Lounge | 3 | 05-12-2006 02:12 PM |
| Alternate fuels | D200Dodge | Hotrodders' Lounge | 15 | 02-10-2005 01:52 PM |
| Alternative fuels E85 | wrenchturner | Hotrodders' Lounge | 4 | 05-09-2002 06:35 PM |
