New gas sending unit not working?
Working on a 1930 street rod 350 engine with "Tanks" U2-SS gas tank in the trunk. Previously the car had a floatless sending unit in the gas tank. It worked fine for about 10 months then went bad. The wiring for the floatless sending unit consisted of 2 grounds, 1 wire from the gas gauge, and 1 hot wire from the fuse panel, total of 4 wires. Gas gauge and wire is new.
We have decided to replace this with a universal "old style" sending unit with a float, model number SN-35. This is a brand new sender and there are no directions telling you how to wire it up. The top of the SN-35 unit only has two terminals. I connected the wire from the gas gauge to the center terminal (goes to reostat), and a ground wire to the other terminal on the mounting flange. I have the sending unit out of the tank and with the ignition switch in the on position, I am moving the float up and down but I am not getting any reaction on the gas gauge at all. Can someone tell me what I am doing wrong? |
Sending unit and gauge match
Yes the sending unit and gas gauge match. This is a 33-240 ohm matched set.
If u can take and wire the gage and the float unit direct to the battery not thru the ignition sw & it works then u have a prob in the car wiring and if it doesnt work then it is in the gage or sending unit. Try going from the gage To ground and the gage should peg that will give a good test for the gage. Ground the wire going to the tank.
No voltage at gas gauge
OK I found the problem. I took a volt reading at the gas gauge with the key turned on and did not get any voltage. The wire that feeds the gauge comes from a switched terminal on the fuse panel. I checked the fuse panel and got a reading so I knew then the wire was bad. I fished the wire out of a spegetti network of wireing and discovered a rodent had chewed the wire in two. I installed a new wire from the fuse panel to the gauge and it works great now. Thanks to all who responded.
| Sending Unit Not Working ???? | cashflow55 | Electrical | 7 | 10-11-2008 07:56 PM |
| Gas Tank Sending Unit | Steve Heyward | Hotrodding Basics | 3 | 10-11-2008 04:46 AM |
| '2001 Malibu temperature sending unit not working | lamothe1 | Electrical | 16 | 03-14-2007 10:41 AM |
| Gas sending unit OHMS? | Siggy_Freud | Electrical | 4 | 12-13-2004 01:21 PM |
| Gas Gauge stopped working has power to it maybe sending unit??? | 61ChevyTruck | Hotrodding Basics | 8 | 11-04-2004 09:02 AM |
