New gas tank for a 47 ford pu - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-16-2005, 04:45 PM
Hi All, I've got a 47 for pick up and I'd like to relocate the gas tank under the bed. I'd like the filler to be located on the rear of the rear fender (lots of room).
Has anyone done this or simlar and can recommend a tank and etc.
Old 09-16-2005, 11:56 PM
jalopy45's Avatar
Give No Limit Engineering a call. www.nolimit.net . If you give them your frame measurements and how deep you want it, they can do it. I got an 18+ gallon tank in my '45 that works great.
Rods Built By Owners(RBBO)club member
wrecking yard archeologist
Old 09-25-2005, 09:19 PM
Tank re locate
If you have good welding skills like me you can mod orig ,unless it`s too far gone. My tank had been setting for years empty,inside a barn. I cut a seven inch section out of it,sand blasted the inside ,cleaned it really well and welded the pieces back together. I sealed over the weld with silicone and coated the inside with tank sealer ,"made for gas tanks". Also moved the inlet tube to where I wanted it. I did this because I could and because I`m cheap and of the Rat rod persuasion "sp" Good luck which ever way you go. Jerry
Old 09-26-2005, 08:28 AM
the tank from a 64 1/2 - 66 mustang will fit between the frame rails. You will need to remove approx 1/2 - 3/4 off of the top of the frame at the rear . Use a mustang pickup & float assy. Calibrate the gauge to Ford operation.
Old 09-29-2005, 12:27 PM
How did you route the filler tube?
Thanks, Tony
Old 09-29-2005, 01:31 PM
the fill is at the back of the tank, i cut a hole in the bed, attached a SHORT piece of hose & a short ipiece of fill neck. when we redo the bed this winder, i plan on raising the floor a couple of inches. Then i can get a door from rock valley, or hagen, and hide the filler neck
welding on a used gas tank mychevystang Garage - Tools 5 10-10-2004 09:33 PM
37 Ford Gas Tank Ted's37 Body - Exterior 11 02-02-2003 05:50 PM
Gas Tank for 33-34 Ford Bill Ford Engine 2 11-23-2002 06:24 PM
priming for 1st start w/new gas tank required? bullheimer Engine 4 08-09-2002 07:05 AM
replacing gas tank in 29 Ford pikalpha Engine 2 12-10-2001 04:45 PM
