new gears break in - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-13-2003, 05:21 PM
Post new gears break in
should they make alot of noise at first? they dont really make much or any noise when there is a load on them, only at the point where the engine and the drivetrain are spinning but with no drive or cost load. what do you think? it makes a high pitched whining noise. my old gearset did but not this intense.
Old 05-13-2003, 06:36 PM
zonk's Avatar
Home Built Rods No Rules
Last journal entry: Home Made Sheetmetal bender plans
Post
I've been told certain gears are more noisy than others,did you brake the new gears in properly by running them easy for about 20 minutes,letting them cool down completely doing that 3-4 times before hard starts? gear lash set properly?
Old 05-13-2003, 07:29 PM
Post
I have been running the break in and the first time the noise concerned me. it is a high pitched whine and its loudest at around 45 with no load. I can feel it though the car. I used the old shim new bearing and I came out with a bad pattern on the teeth so I swapped the carrier chims side to side and it gave me a pretty consistent pattern in the center of the teeth. I know what the pinion depth is all about but never understood what backlash is, could you explain?
Old 05-13-2003, 09:15 PM
johnsongrass1's Avatar
Race it, Don't rice it!
Post
If I remember right the pattern should be slightly off center toward the toe. Can somone back me up?
Old 05-14-2003, 05:04 AM
zonk's Avatar
Post
check out www.ring-pinion.com go to tech library also try, go to knowledge base put in ring pinion for search go to article # 27 hope this helps
