New GM ZZ383 Stroker Oil Consumption - Page 4 - Hot Rod Forum : Hotrodders Bulletin Board
  #46 (permalink)
Old 04-21-2013, 09:45 PM
gonzo08383's Avatar
Last journal entry: brakes
most likely shouldn't use synthetic before the engine is broken in. usually takes 500 miles or so to fully break in a motor. I've built a few and none have ever smoked, ever. usual culprits are valve seals, improper ring installment, too much oil, leaking rear main(2 pc seals are infamous for this), wrong oil type. I recommend 15w-40 rotella for break in. switch to synthetic after 1000 miles.
  #47 (permalink)
Old 04-22-2013, 10:31 AM
I drove my truck yesterday about 75 miles and the oil level has not moved a bit so far. I must admit the dealer's service dept that I bought the engine from has been very good to deal with. This engine has some torque reminds me of driving a big block.
  #48 (permalink)
Old 06-25-2013, 10:03 PM
Im Back... GMPP Makes Good I Think???
If you have followed for the last 7 months or so I have had two GMPP ZZ383 Strokers that have been oil users. The first one GM replaced after less than 1500 miles because it flunked a leakdown test. So they sent a new one. That motor used oil at a lower rate, but still unacepatble. So thay had my installer try a few things and then had me put over 4000 miles on the motor. No improvement. Well I just brought it back, post 4000 miles, and GM has decided to send another motor. So I am hoping that three is my lucky number and after this motor is broken in I can finally drive my car without documenting everything I do. Just want to run my car and enjoy it. One would have thought that for the $$ I spent I would have been doing that almost 1 year ago.
  #49 (permalink)
Old 06-28-2013, 01:29 PM
Boy, I really wish you the best.
  #50 (permalink)
Old 07-01-2013, 01:31 PM
Just as a note on oil consumption, I just put 1280 miles on the 57 Chev with the 283 PowerPack. 3/4 of a quart of oil was used for the trip. This on a 25 year old stone stock rebuild with a 0.040" overbore now with 80,000 miles on it. The extra 100cubes that the 383's have over my 283 should use more oil, all else equal. But you'd think that the newer tech in the 383's should seal up better than a 283 with the crankcase vent tube.
Good luck with the 383's guys.
peace
Hog
  #51 (permalink)
Old 05-12-2014, 05:51 PM
joeford's Avatar
36 Dream
Just completed build on a 36 ford coupe with a zz383. Just finished break in with slightly over 1000 miles and I have oil concerns. Given the fact that I bought this crate some 6-7 years ago I doubt GM or the dealer I bought it from will listen to me. I note a lot of experiences in this thread. Question is whether there is a common problem. I may just buy cheap oil as I don't want to pull the engine or even go down from top or up from bottom.
  #52 (permalink)
Old 05-12-2014, 11:02 PM
gonzo08383's Avatar
I break mine in using no breathers but instead two pcv valves. The object being to create vacuum in the crankcase. It helps the rings seat quickly. Ive been told this method can cause the main seals to prematurely fail though. I don't know if it does help but it didn't seem to hurt my engines. Do you suppose ethanol fuel has anything to do with your problem? It's a very long shot but maybe? I can't believe you're having this kind of trouble! GM must be slacking in the qc dept. Good luck and let us know what you find.
  #53 (permalink)
Old 11-24-2016, 09:24 AM
402Z28's Avatar
Air smith,
How did #3 turn out? Last winter, January of 16, I installed a SP 383 in my 78 z28. Consistently burns a quart every 520+- and does not smoke at all. Chevy Performance has agreed to replace the motor but the new version is back ordered. I'm #48 on the waiting list. I'm curious if you ever heard what caused the consumption issue and if #3 was good. Please message me if you wish not to post.
  #54 (permalink)
Old 11-24-2016, 10:26 AM
64nailhead's Avatar
Sounds like GM has a dilemma and knows it, but you're probably not going to get a response from the OP due to almost 3 1/2 years ago.
gmpp 383 stroker, new 383 crate, new zz383, zz383 break in, zz383 oil
oil consumption 2old2fast Engine 9 04-26-2016 05:37 PM
So frustrated/oil consumption bygddy Engine 13 06-10-2011 12:35 PM
New build oil consumption??? CJ_1080 Engine 28 06-05-2011 01:48 PM
Oil consumption due to possible sucking oil from intake valley..signs ? y2k600f4 Engine 10 07-31-2010 05:40 AM
oil consumption 4doorjoe Engine 10 07-04-2005 07:20 PM
