New guy with a 111W and sewing problems, I'm sure that isn't something new! - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-02-2012, 07:23 AM
Hi Everyone,
I picked up a 111W155 a few weeks ago and I'm working on getting use to it. I absolutely love it with one exception, I'm having a tough time with my thread bunching up underneath the material and also in the bobbin area.
It all started when I found out I had my maching threaded incorrectly. Once I corrected it, I starting having these issues. So I figured that it was my tension that was messed up. Well if I loosen my tension on my upper thread, the hook doesn't seem to grab it, and if I tighten my upper thread, the thread breaks. I don't recall a time where I was so upset with a machine cause I didn't know what to do. I decided to replace my bobbin case as some people have had luck with that but that didn't change anything. I'm starting to question the possibility that my hook is slightly out of time. I read up on how to time it and was curious as to what people used for measuring the needle position and hook position (1/16 and 3/16" dimensions)
I'll work on uploading a picture later today, thanks guys!
Matt
Singer 111W155
Old 06-03-2012, 09:52 AM
Well after finding a troubleshooting guide, I'm pretty certain that my timing for my hook and needlebar isn't set correctly. I did find a manual from the navy and when I was reading up on how to time the hook, it doesn't show the picture to tell me what is what. (it mentions to look at figure 4.6 and 4.6 doesn't exist!)
http://navyaviation.tpub.com/10330/css/10330_57.htm
sooooo........That's where I'm at so far. If anyone has any extra input, please feel free to add it. I will see what I come up with today. Thanks!
Matt
Old 06-03-2012, 01:22 PM
Here is a link to the singer 111 manual. Hope it helps. click here
Old 06-06-2012, 08:56 PM
GOT IT! I finally noticed the timing mark on the needle bar and I was indeed off on the hook. I adjusted it and it's working better than ever!
111w bobbin case jammed catuch Interior 12 05-13-2012 09:04 PM
Singer 111W Controller? Coodeville Interior 5 08-04-2010 01:37 PM
111W Loose Feed Dogs? Coodeville Interior 2 08-03-2010 01:21 AM
I actually wanted to post a craigs...singer 111W machines Introduce Yourself 2 07-12-2010 12:46 PM
Bobbin Winder on 111W? Coodeville Interior 3 02-10-2010 09:14 PM
