new guy here...compressor lines 3/4 inch - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-11-2005, 01:49 PM
hello guys/gals....I just got my new used compressor...it has a 3/4 inch outlet ...the fella I bought it from told me to run 3/4 pipe all the way.....
my question is ....shouldnt I reduce down to 1/2 inch down the line somewhere??
btw..where can I find 3/4 inch flex pipe from????
Old 04-11-2005, 02:12 PM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
I would check a hardware store for tubing and stuff, and welcome to the forums!
Old 04-12-2005, 06:20 AM
Beenaway2long's Avatar
or Jeff, or Doc, or...
Last journal entry: Results of the Camaro
The 3/4" gives more air volume, and less restriction, meaning more grunt at the tool. You can use 3/4" hardline (I preper black iron pipe-search all the piping questions) and neck it down at the outlet. Then use as short of a hose as possible. I prefer 1/2" hose with 3/8" high flow outlets (Napa sells them). The connectors are more $, but the tool gets all the air it can. Especially when it comes to paint guns.
Old 04-12-2005, 11:28 AM
I will have about 25 ft of black 3/4 pipe....but when I get to my filter and regulator ..should i reduce the size at the filter and regulators....or find filter and regulators that have 3/4 fittings...????
Old 04-14-2005, 07:11 AM
I'd keep it 3/4 as far as you possibly can.
Old 04-15-2005, 10:57 AM
I think Grainger sells them if you are made of money. I got mine made at a local place (princess auto) for $12 or so in the hydraulic department.
9 inch rear end Crazy Man Transmission - Rearend 3 08-26-2003 08:34 PM
please help me 8.8 inch or 9 inch martion Transmission - Rearend 5 03-15-2003 11:57 AM
Art Carr 10 inch converter Marcus Transmission - Rearend 11 12-30-2002 04:47 AM
5.7 or 6.0 inch rods???? chevyelc81 Engine 4 07-03-2002 06:36 PM
driveshaft conversion? 8 to 9 inch mustang66maniac Transmission - Rearend 5 05-16-2002 02:49 AM
