Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - New guy needing advice before I drive myself NUTS!!!! (355 build options)
Old 10-18-2009, 07:10 AM
SSedan64's Avatar
SSedan64 SSedan64 is offline
If you can afford the AFR 195s, they're better. Build the 383 with compression you want, then call Isky, Comp etc.. for the cam recommendation. I wouldn't worry about the Trans as much as the rear.
What rear do you have in the ChevyII?
