New head gasket leaking.What did I do wrong - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-27-2005, 05:08 PM
New Member
I had my 202 cast iron heads redone on my 350 chev I put every thing back together and after I drove the car for a while when I got home I was checking every thing out and I see that I have a coolent leak on both sides of my heads driverside and passenger side it seems to be comning from one of the head bolts it is just a weep not a steady flow.I drained all the coolent from the block and pulled the 2 head bolts cleaned them and put them back in re-tork took the car out for a nother drive same leak.Do I have to take the heads off and start all over or should I just wait to see if it gets worse.The car is only driven to car shows and only gets about 2000 miles on it a year.
Steve
Old 08-27-2005, 05:25 PM
steve t's Avatar
ex biker, now hotrodder
put some thread sealer on threads, and retork,some bolts go into water jacket
Old 08-27-2005, 05:39 PM
arch's Avatar
My bike has 4wheel disc brakes
I agree, if you dont want to pull the heads again, take those bolts out, thread sealer, or teflon tape, retorque those two bolts and the 4 or so bolts around them. If it still leaks, I'd say pull the heads, get new gaskets and try again. Problems always get worse, never better.
Old 08-27-2005, 08:57 PM
Jmark's Avatar
Pull the bolts and clean them real good with lacquer thinner or gas. Dry them good and put some Permatex #2 on them. Don't be stingy either. Put them back in and re-torque, should be fine.
Head gasket size??? batman09 Engine 10 12-17-2004 12:00 PM
Cracked Head or Blown Gasket? '71 rag top Engine 1 12-15-2004 11:08 PM
oil on head bolts and head gasket bullheimer Engine 7 05-25-2004 05:50 PM
Head Gasket installation '67Pony Engine 3 07-27-2003 12:33 PM
BB CHEVY HEAD GASKET Studebaker Engine 1 02-07-2002 05:21 AM
