New head unit on a 62 cadillac - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-05-2005, 12:32 AM
rbfpezcore's Avatar
Not fast, but loud as hell
New head unit, old speakers
I am installing a new head unit on my 62 cadillac. But the speakers are old. The head unit requires power and ground to go through the speaker, but I cannot find a ground wire. I assume it is grounded to the car itself. Should i leave the speaker grounded to the car and just provide power or should I buy new speakers? thanks
Old 08-09-2005, 10:21 AM
USAF F-16 ELECTRICIAN
your new hea unit is going to be too much power to your old speakers. and you definetly dont want the speakers to have a common ground. they dont sound good like that at all, you will have alternator feedback. just buy some cheap replacement speakers from walmart or a pawn shop and some cheap wiring and wire them yourself. it is fairly simple.
Old 08-09-2005, 04:46 PM
docvette's Avatar
Wiki Edits: 12
Confused
Doc here,
Shaking head like crazy....
POWER and GROUND SHOULD NEVER be applied to a Speaker....
Unless you enjoy shooting paper wads, smoke and fire...let's see..650 CCA through 4 , 8 or 16 ohms to ground through a speaker cone made of 26 gauge wire..." Save me Mr Wizard!!!".....trissel,trazzel, trussel, trome...time for this one to come home......"
Is this a HEAD unit..as in Remote Dash mount controller..Only, or a head unit that includes a trunk mounted amp as well?
If that's the Case, the AMP will require a POWER(about 4 gauge cable) and HARD ground (about 4 Gauge) an AMP energize line (usually blue 18 gauge wire that runs to the radio power antenna wire)
Your line or RCA INPUTS From the Radio/CD audio OUTPUT harness, to the AMP usually +left -Left, +right -right, -right rear, +left rear, some systems, center or sub-woofer.
Your AMP OUTPUT will consist of : +left-left, +left rear, -right rear, +right -right, Center or sub-woofer from the AMP..
NEVER ground ANY speaker on ANY modern audio system to a hard (frame) ground, or you will destroy the audio strip-line brick inside the amp from thermo overload..By modern, I mean any radio that is stereo, over 1959 vintage,and is solid state.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
62 cadillac 390 baby huey Engine 20 11-12-2009 12:02 PM
Disc brake conversion for a '62 Cadillac kaddylowrider Suspension - Brakes - Steering 2 03-17-2004 06:46 PM
COMPLETLY rewiring head unit. Rubberman2003 Electrical 3 08-07-2003 05:05 AM
SBChevy Head Gasket is oil soaked 360Camaro Engine 2 08-04-2003 10:44 PM
Cam Help black66 Engine 3 05-12-2003 07:15 PM
