New heads need piston/compression recommendation - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-12-2010, 11:03 PM
Just purchased a set of trickflow heads and wanted to know if I should be shooting for 9:5 or 10:1 compression. I will figure out cam a little later, but in search of a piston and compression to start. I know with alum heads you can run one more full point compression. I read an article where someone built a 9:3 compression motor that made close to 400 hp with these same trickflow heads. The article stated that the car will be ran on 91 octane, but with the compression being lower (below 9:5) it could possibly even run well on 87 octane. What seems to be the threshold for these heads and street driving. I believe too low can hurt too as well as having too much compression.
My question is what should I be shooting for for compression. This will be a pretty much stock 306 other than the TFS 170 heads.
Old 12-12-2010, 11:31 PM
Greg T's Avatar
www.krusinklassics.net
You should decide exactly what you want the engine to do and the rpm range you're going to run. Then decide on a cam that will fit those criteria and use the compression ratio that suits the cam.
Old 12-13-2010, 09:31 AM
cam timing has a huge effect on the amount of compression that can be/should be used.
If the cam is stock, then you could run 9 to 9.5 with aluminum heads.
I would use 9:1 if there is a big load on the engine (pulling a trailer).
AFR or Vortec heads? Cam? rodent Engine 18 06-08-2010 04:50 PM
Aluminum Heads scenario of potential problem of cause of oil consumption (long) y2k600f4 Engine 37 09-14-2009 06:22 PM
sbc heads shieldbreaker Engine 5 08-27-2005 09:12 PM
Heads and Intake combo black66 Engine 4 07-24-2005 12:33 AM
looking for some head(s) now i'm gonna explode! bullheimer General Rodding Tech 25 04-12-2004 02:16 PM
