Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - New heads and strange coolant leak
Old 11-08-2004, 09:06 AM
TSip TSip is offline
Thanks guys will check these areas out when I get home and let you know if I come up with anything! We did use a small bead of silicone around the water passages on the intake when we installed it but that's not to say there it wouldn't leak anyway....
Camaroman7d, yes we wid use ARP thread sealer on the bolts, I did not pull a valve cover last night because when I noticed the leak and I thought it was actually leaking past the pan gasket we shut it down to keep it from doing any more damage than necessary. Will change the oil this evening and give it a check to see.
