New HEI distributor but no spark. - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-26-2010, 07:02 PM
Crazy-J's Avatar
Hi all,
I have a 1969 Camaro with a 1978 Corvette L82 350. I installed a tach but the old cap had no tach hookup so I installed a new cap and rotor. I tried to start the engine but it wouldn't fire. I checked for spark but I wasn't getting any.
To make a long story short, I installed a new distributor (which came complete with cap and rotor) and when I tried to start it this time it backfired up through the carb like it was out of time so I thought I had fixed the spark problem. But I tried to start it again but it wouldn't do anything but crank over. I tried several times and checked for spark again but I didn't have any.
All of the components of the distributor check out with an ohm meter and I have a keyed 12v wire hooked up to the BATT side of the distributor.
Any ideas as to what I could try next?
Thanks!
Old 09-26-2010, 07:15 PM
Probably a far shot, but I had that exact same thing happen a week ago with an hei distributor. Turns out the tach wire had rubbed against some metal and was grounding out. So I would try removing the tach wire and just having the 12v hooked up. Like I said, its probably a far shot but that's one less thing that could be the problem. Good luck my friend.
Old 09-26-2010, 07:47 PM
LATECH's Avatar
In the years of wrenching I have done, there has been two or three cars that have had ignition problems due to a bad tachometer. Try disconnecting the tach and see if it starts . if it does, plug in the tach and see if the motor shuts off.That should narrow it down some.
Old 09-28-2010, 11:54 AM
Crazy-J's Avatar
Thanks. Unfortunately I never got around to actually hooking up the tach because of the other problems.
350 TBI spark problem driving med crazy!! Erst Engine 13 09-27-2016 04:39 PM
Chevy HEI - Weak Spark daveturnbull Electrical 5 07-25-2011 09:58 AM
MSD No Spark Canadian Charlie Electrical 3 04-14-2006 06:15 PM
HEI: No Spark Goobzilla Electrical 17 04-17-2003 12:27 AM
Do I Need Little HEI Box for New HEI Dist? Mr.56Chevy Electrical 0 12-23-2002 02:38 PM
