new here 383 4 bolt questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-19-2011, 10:50 PM
hi i recently bought a 71 chevelle with all mods listed below,
383 4 Bolt Main, 202/194 Double Hump Heads, Stainless Steel valves with Titanium locks, Double spring valve springs, 11:1 Comp, Forged flat top pistons with 4 valve release, lightened crank, Solid lift cam, Aluminum Roller Rockers, MSD Ignition, 2800 Stall Converter, 350 Turbo with B&M Shift Kit, B&M shifter, Auto Meter gauges, Super Tach., Aluminum 4 core radiator, electric twin fans, fuel cell with electric fuel pump, Holley 850 Demon Carb.
so have a few questions i am an ls1 guy with fuel injection so this is entirely new. first of all i dont like the heads on it ive been told there old school and i could do better with modern heads. so what heads would you guys recommend for this engine that would fit nicely? im also looking to convert it to fuel injection ( gotta go with what im comfortable with) but thats another story. mainly the heads are my main concern right now looking for suggestions.
Old 10-19-2011, 11:22 PM
SSedan64's Avatar
No need to Post your question in 2 Forum Sections. Check the other one in Hotrodding Basics.
new here 383 4 bolt questions usnfenix Hotrodding Basics 6 10-20-2011 06:24 AM
Big 10 bolt questions. Chrome407 Transmission - Rearend 3 09-11-2011 01:34 AM
gm 10 bolt 7.5 questions pena0724 Transmission - Rearend 2 07-16-2009 08:07 PM
GM 10 bolt rear end questions pena0724 Transmission - Rearend 20 03-31-2009 08:56 AM
questions about swapping R/E gears from a 12 bolt Gm into a Pontiac 10 bolt housing l Bad Rat Transmission - Rearend 6 06-11-2007 10:50 AM
