New here, big fan of the forum, need a little help from the experts and vets please!! - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 03-11-2013, 10:05 PM
In a K5 with 33" tires and 3.08 gears and a overdrive transmission. The absolute best mod you could do would be to regear. With that cam and heads and a 700R4 you would be so far below the good part of the torque curve of that engine it would cost you in many ways. 4.11's or even 4.56's would be a way better combo to start with. With the gearing you say you have now and those tires. You wouldn't even need to hit a hill. All you would have to do is whisper the word hill and you would have to down shift 2 gears. I know in the OP you said you were going to address this issue. But if you want this truck to run halfway decent you should think about regearing before you put that engine in it. I'm not trying to be smart here it's just that I have seen this done so many times. The next step for alot of guys that do this is to come back to this or other forums and complain how they cannot get their truck to run worth crap and how it's not responding to tuning. I really mean no harm by this I am really just trying to help. And it maybe that you have already thought of this and have a plan to address it. If that's the case then disregard this post. Thanks Bill
The Following User Says Thank You to Ironpony For This Useful Post:
NCmike (03-11-2013)
  #17 (permalink)
Old 03-12-2013, 12:55 AM
350
Yes, that cam is smaller then I'd have preferred, but you have improved those numbers a tad with the Erson 1.6 rockers. Cams are important, but nowhere near the importance of your heads. Honestly, if you simply install Summits Sealed Power flat top pistons with 6cc valve reliefs, you'll boost that CR up to about 9.8. On my desktop dyno, with a few fabricated flow numbers from your heads, you'll be around 365 ft lbs of torque and 315 hp at 3800 RPMs. Theres no shame in those numbers at all. If you go that route it will cost you about $250.00 more, but also gives you all new gaskets and bearings. Engine shop will hang your pistons and rods for you for $100.00. Small price to pay to get to your goal. Going into your truck the torque numbers are ideal and gives you alot of room to grow.
  #18 (permalink)
Old 03-12-2013, 03:36 PM
Ok so as of now instead of doing the pistons which the machine shop quoted me way more than 300 including getting the Pistons, new rings, cam bearings, polishing the crank etc etc it was over 1k. They are one of the most reputable and honest shops around so I trust them but that was getting to expensive for what I can do right now.
So I am having the heads milled from 74cc to 69cc, also running thinner gaskets we did the math and my compression came out right at 9.5:1 which is ideal for what I was looking for and I also ordered a whole different cam.
Old cam specs...212/218 @.050 256/268 duration .447/.454 lift
New cam is a 4x4 extreme cam...218/226 @ .050 262/270 duration .462/.48 lift
So What do you think now?
Thanks!
Oh and 4:11 gears are next in the truck!
  #19 (permalink)
Old 03-12-2013, 04:31 PM
vinniekq2's Avatar
before you buy 4.11 gears,use a gear speed calculator.
Gear Ratio Speed Calculator
double check end results desired
The Following User Says Thank You to vinniekq2 For This Useful Post:
NCmike (03-12-2013)
  #20 (permalink)
Old 03-13-2013, 10:48 AM
Ok will do! Thanks so much for your help Snakebit
btw I also got an Air gap intake now as well instead of a performer. So more compression, 69cc heads as opposed to 74 and a bigger cam. I should be close to 350HP and 380ft lb torque or more by now I believe, what do you think??
  #21 (permalink)
Old 03-13-2013, 11:18 AM
Check out this link and look at the second Test and the numbers it put out on the Dyno. My heads are better than the 882's ported and I have 1.6 rockers as well. I'm thinking I'm going to be close to these numbers.
350 Engine - Packaged Performance - Super Chevy Magazine
350 sbc build
Big ***** Fan for your shop birdssb Garage - Tools 7 06-02-2011 10:29 PM
Big Block Camaro Fan ? BigBlockCamaro Engine 2 05-29-2008 06:25 PM
big block fan dj454 Introduce Yourself 2 05-04-2006 12:56 PM
Hi guys. I am new here. Just another big hotrod fan. 84Z28_Project Introduce Yourself 2 02-11-2006 07:12 PM
a very big boss 302 fan bosshog Introduce Yourself 8 01-08-2006 11:54 PM
