new here need sbc timing/vacuum advance help - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-17-2013, 11:27 PM
I have a fresh 421 sbc brand new everything including hei distributor. Howards hydraulic roller cam close to 600 lift w 1.6 lifters (still makes good vacuum based on specs for sure and I can verify it does) Holley Ultra Billit 770 carb on Vic jr manifold. 10.77 to 1 using gapless top ring.
OK> problem is setting timing at 10 at idle of 950 w no vacuum advance hooked up and goes to 34-35 at 3500 to 4000 THEN I hook up the vacuum advance and it jumps to 38 to 40 at idle?!?!?
Also getting some popping/backfiring off idle when throttle is applied? ?? WT (HECK)? Howards said to set lifters at 1/4 turn pressure and I set them at about 1/3 turn from zero lash ( could they actually be staying slightly open from this tiny amount extra and be creating the backfires? )
New to this whole sbc gig so any help would be great for sure.
Old 06-17-2013, 11:35 PM
techinspector1's Avatar
Wiki Edits: 326
If you adjusted the valves by twisting the pushrods against the spring in the lifter, they are too tight. Nobody but a builder who does this every day, all day long, will have the finger feel to get the lash right. Use the "jiggle" up and down method.....
http://www.crankshaftcoalition.com/w...stment_SBC/BBC
Timing and vacuum advance? fordSR Engine 3 10-29-2011 12:43 PM
vacuum advance and timing modern look stroker444 Engine 1 10-24-2010 12:33 PM
1958 Olds 371 Timing and Vacuum Advance question gregplus40 Engine 2 08-17-2010 05:37 PM
Timing... vacuum or no vacuum advance? 454ChevelleMalibu Engine 17 04-25-2010 10:37 PM
Vacuum Advance/ timing confusion! Zeder Engine 4 07-11-2003 03:25 AM
