Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - New here and would like an opinion
Old 10-26-2003, 11:05 PM
crazy larry's Avatar
crazy larry crazy larry is offline
Last journal entry: better comparison before and after shots
the jet wash was done in like 90 seconds(crank shaft only)
i wouldn't jet wash a grimy block...... the hot tank was most likely a couple a days.....(real grimy) they both left some goo that needed a little persuasion, but i guess if i had my druthers, i'd hot tank. just make sure you pop all of the oil plugs and freeze plugs out. esp. the little oil galley plugs, as some machine shops won't take the time to.........
ask your machine shop what he gets for a good 350 core...... and crank....... just know which casting numbers to look for.... or not to look for........
note the use of varying (.)'s
