Don't know if it's true but I once read on the CorvetteForum that Pro Comp stuff is made in China and often distributed thru Australia. When they first started importing heads, there was much negative feedback. I have heard that the quality of their new generation of heads is much improved. I have no personal experience but I'm sure if you Google the company, you will get lots of opinions.
Terry |
Hi
There's some talk about the blocks over at http://www.yellowbullet.com/forum/sh....php?p=2639016 & http://www.nmradigital.com/forums/sh...ad.php?t=94252 Like the rest of there products not much good said about them. Rich |
Now. I read these posts on yellowbullet etc. Most are a year or two old and most are posted by armchair experts, wise azzes and China haters..(Wake up people!. Your political reps, taxes and tree huggers have made it way too expensive to manufacture in the US. I'm sad to say).
Only actual complaint was soft material in blocks.. I'm sure that has been remedied. It was too late in the day for me to actually measure the block. But I know what to look for after building SBC's since 1965. I know quality castings/machine work. This block looks like no other I've seen, as a factory fresh block.. |
Can you test the hardness?
Post some pics Bob. The Chinese can do some superb work if you pay them for it. When Super Tigre R/C engines which were formally made in Italy sold to a Chinese firm I was bummed out
. I have used Super Tigre glow engines ever since I can remember. I have since bought several Chinese Super Tigre glow engines and they exhibit excellent metallurgy and run just as strong as the Italian versions.Vince |
Sorry, I've never been able to down load photos on this site..
Today I was busier than a cat coverin crap. But, I did check the mains/line hone on this block. Right on the money. This thing takes the Aftermkt/Dart style cam bearings etc. Honed to spec for the pistons with a few strokes of the CK 10. Nice round cylinders. Deck is perfect finish. NOT rough like a Dart block. |
I talked to the distributor for ProComp in this area. The block is 100% done in Australia. Then shipped to China where it is marked made in China. Then shipped to the USA. Something about they save 8% by doing it this way..
Checked all the specs and the thing is right on the money. I swear it weighs as much as a big block. Any ways the block went to it's owner today. Going to have a 4" arm, the Auto Tech pistons and two stage 750 hp. nitrous system. |
I think pro comp is blowing smoke up your ***. They will never see a dime of my American money.
You will be missing a lot. ProComp plans on being a major player in the high performance game. Besides most of the automotive parts now days are imported. No matter what brand name is on it.
I've noticed ProComp has been doing a lot of advertising lately, Sponsorships also. Probably is cheaper doing the Aussie deal, most all China Steel is imported, $$. |
Lets say I use to work for a company that made gear couplings. I ran a Okuma LC30 CNC Lathe. My job was to take the coupling and bore the hole in it and get the bore size to .0005 within tolerance. Big deal mcneil.
Anyways. Since the company starts getting some of these couplings from another one of our plants, which was in China, it wasn`t made of the same steel we had here in the states which I seen was always on quality wise, especially the harder red steel. The China pieces I used to have quite a laugh with. It only meant I`d be changing the insert alot more often due to one coupling would be so soft, the metal would sling off like globs of butter so the part came out oversized without a acceptable wall finish as well as bore taper. The next would be so hard it would kill the insert half way through the part meaning you were going to have to do it over plus get the size right with a new insert. Those things made for fun all night long. When the drill and tap guys got ahold of the parts that made it to them, the soft ones had threads that wouldn`t hold up to the thread checker, the hard ones were so hard a regular drill bit wouldn`t bore through them so they had to use carbide tip bits. I was happy when we finally stopped running those couplings and stuck to running our own. On the ones with the bigger bores, when clapped in the jaws the pressure had to be lowered to keep from knocking the part out of round. While this thread has nothing to do with the block Bob got, it sure showed me what china metal was like. This was years ago, but for some to be so soft it was like butter, and others to be so hard it killed inserts was plenty of lesson for me. The real kicker was, I wondered what the plant`s customers thought of those soft couplings when the run out was so great they likely failed the first time they were used over 2000 RPM. That was the first time I ever seen steel that was like rubber. Sure made me scared of china pieces after that. |
It is common knowledge that these companies in China that turned out bad products and caused embarassment had CEO's that were executed,here in the states a CEO can screw up a company and walk away with millions in severance pay.Pro-Comp quality should be improving as I am sure they are keeping tabs on what we think of their products.
You don't alwyas go by looks.
Here is copy and paste on the make believe Dart blocks. Quote:
| BBC block cast. # for truck but says hi perf pass? | RJs73camaro | Engine | 6 | 11-17-2009 05:11 PM |
| Hi Perf V-6s | Esstenner | Engine | 2 | 06-06-2009 09:33 PM |
| 496,8.1, 8100 vortec. perf. parts,swap into 5-6-7 chevy | louis | Engine | 9 | 06-22-2008 01:45 AM |
| Low perf 454 ??? | Augusto | Engine | 1 | 04-10-2007 07:55 PM |
| differences between perf. and perf. rpm | 85CHEVY | Engine | 2 | 03-08-2007 03:29 PM |
