New High Torque Starter Connection prob .
Ok Guys ,, Here is my thing on this New Starter ..
I have a 70" BBC .. I swaped the old starter of the engine , & I got me a Mini starter .. I got it all hooked up & tried to start the car .. BUt The starter would just spin .. The Shaft would not come out of its shell for some reason .. It just spins ... ( I was thinking I might have switched the wires wrong ) I gave up ,, & I took the starter to get checked ,,, & It checked good .. They hooked it up to the tester ,, & shaft came out properly ,,, The way it was supposed to .. So I took it home & tried switching the wires around again , But It still did the same thing (Nothing but just spin ) Without the shaft coming out ... Can someone please Help .... ? The wiring harness & car is a 72 Camaro ... Stock starter had 3 wires connected to it , PLus the Battery cable ... :welcome: |
is the battery strong enough? if so check the ground. sounds like it is not getting enough voltage to spin fast enough to engage the bendix
71corvette You Got It.
| All times are GMT -6. The time now is 04:00 PM. |
